Hi Guys, As some of you regulars know, I'm doing a one off new house install. I'm now in the process of 2nd fixing Ovia click LED d/lights. Over many weeks reading threads on here about 17th edition joint boxes being of the correct type so as no strain on terminals if cable pulled etc. It does surprise me though when fixing/ connecting the light fittings that the cables (up to 3 x cables @ each fitting) can be connected into the click connector block without any cable clamp to restrain the cables. The click connecting block have 3 x cables entries points, however any cable points that are not used are just left open, no knock outs or blanking off method. Not only that the cables are loose from the ceiling when connecting and then just pushed up through the hole along with the floating joint box. In the loft space, as no insulation laid down as yet, it looks like a complete mess. What are your thoughts re the method of connecting these d/lighters and j/boxes?
