2volts on a disconnected cable?!? | Page 2 | on ElectriciansForums
Discuss 2volts on a disconnected cable?!? in the UK Electrical Forum area at ElectriciansForums.net
I've recently been sent to complete a re wire for another contractor and there is a cable which isn't connected to the consumer unit which shows 2volts on it! is there a reason for this? I'd it potentially dangerous? How can I correct it? It's on one leg off the ring main in the kitchen. Any information would be appreciated I've tested it with my digital multi meter and done a insulation resistance test on IT also which shows its all fine.
Well that's 30secs of my life reading this thread that I'm unlikely to get back again. Jeez.
Reply to 2volts on a disconnected cable?!? in the UK Electrical Forum area at ElectriciansForums.net
It should give fairly accurate results. Bear in mind your car will probably have a smart charging system, so worth having a read up on those.
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
