3 core flex. | Page 2 | on ElectriciansForums
Discuss 3 core flex. in the Australia area at ElectriciansForums.net
B
Bright.Spark
I'm adding a outside light to an. Existing install. The lights have been wired in an rb4. Can I add my light fitting to the circuit but wire it in 3 core flex instead of 1.5 twin and earth?
black is preferable since black is generally uv resistant, more so that white.
hi-tuff is very expensive BUT plain NYYJ cable (which is what hi-tuff actually is wen it is at home) is not that bad.
seems like the ideal to me is black pond flex 3183P, cant seem to find 1.0mm cores though. alt seems to be tough rubber 3183TRS.
Reply to 3 core flex. in the Australia area at ElectriciansForums.net
No table I just know the conductivity of the armour is around 4.0mm² copper equivalent so 6.0mm² will be fine.
As you've found out, there's capacitive coupling between cores which will induce a voltage into other cores when one (or more) is fed with AC. How...
