3 core - what colour do you use as a switch wire? | Page 2 | on ElectriciansForums
Discuss 3 core - what colour do you use as a switch wire? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
something to do with the water in yorkshire. we only allow what we don't want to blow over the ridge.
I had heard that the reason for harmonisation was to get
away from red being used as it is classed as a 'Dangerous' colour, it clearly worked as now every Tom, Dick and Harry thinks they can do electrics.
Still black as switch, grey as neutral.
as msg 6. any other way is a deviation. grey is the old black. im sure its wrighten somwhere.. but im on the beer again, and the chance of finding the page is as good as zero
Ah, this old chestnut.
Black (sleeved brown) as permanent live, because that's how flex 7, rock etc flexes come pre-wired, and because you use brown as switched live everywhere else where you haven't got a permanent live so it keeps it consistent.
Brown as switched live as you usually would if there weren't a permanent live.
Grey (sleeved blue) as neutral.
Also because 4 core flex comes with brown, black, blue, and green & yellow.
Black as Auxiliary live.
Brown as L1 with the feed (also brown) so browns go together.
Grey as L2 (sleeved brown) with the switched live (blue, sleeved brown)
Black (sleeved brown) because it's the other one.
Was told at time of harmonisation to get away from using black as neutral we had to "deneutralise the black" if that's even a word!!
when doing em and normal lighting mixed, it's usually black (sleeved) for perm., brown for switched.
Brown permanent live.
black switch line.
grey switch linear neutral.
harmonisation did state not to use back as neutral any more so that it did not get confused with old black neutrals therefore you had in old 3 phase boards black and greys as neutrals. That wouldn't confuse any body would it.
also I was taught on a 2way switch if you follow the circuit through the switch in the off position then the grey would actually be a neutral.
check it out it s true via the lamp
"harmonisation" did state not to use back as neutral any more !!!
Did he..............where?
Is this harmony guy still on the tools...........so to speak?
And I take it you meant black not back:)
black switch line.
how can grey be a neutral in 2 way switching when they're all live or switched live?
exactly. greg flexes come pre-wired in that exact way. so black as perm L.
Draw out the circuit including the lamp. Back trace the neutral through the lamp to the switch and when the switch is off the grey is connected to neutral. Image the lamp s a link not a load.
i know it's barmey but in some weird way it makes sense lol
Reply to 3 core - what colour do you use as a switch wire? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
As you've found out, there's capacitive coupling between cores which will induce a voltage into other cores when one (or more) is fed with AC. How...
No table I just know the conductivity of the armour is around 4.0mm² copper equivalent so 6.0mm² will be fine.
