3 layers of plasterboard stud wall | Page 2 | on ElectriciansForums
Discuss 3 layers of plasterboard stud wall in the UK Electrical Forum area at ElectriciansForums.net
South West
Hi,
has anyone else ever come across a stud wall that consists of 3 layers of plasterboard just stuck together.
I thought it i had a nice easy job of cutting out a couple of fastfix boxes and fishing tv and Power cables into loft but as i was cutting out the boxes i realised it was a bit thick, double boarded i assumed so started cutting a bit deeper but then realised i had daylight! went straight through to the kids room the other side!! after a lot of head scratching/measuring i realised the wall consists of 3 sheets of plasterboard basically stuck together dot and dab style. Didn't come across any timber but i'm guessing there had to something somewhere.
The complete thickness of the wall was only about 70mm so couldn't as even fish cables up as it was too tight and had to chase the whole route up which i lost a lot of time on!
Never come across a stud wall like it, didnt know if anyone else had? The housing estate was built approx late 80's.
20mm hole in board
35mm of 20mm plastic conduit as a sleeve, to avoid bridging the thermal barrier.
Drill wall, long screw and plug,, done.
Or window frame fixings as they have a built in sleeve.
Reply to 3 layers of plasterboard stud wall in the UK Electrical Forum area at ElectriciansForums.net
An example of the long term race to the bottom of quality of work in our industry, IMHO.
