3 of 6 GX24Q-4-pin type pots lights went out together any ideas? | on ElectriciansForums
Discuss 3 of 6 GX24Q-4-pin type pots lights went out together any ideas? in the DIY Electrical Advice area at ElectriciansForums.net
70Tbolt
California
3 of the 6 lights run by the same switch went out at the same time. Tried new bulbs, switching bulbs that worked no go. When the switch is off and I go to insert a new bulb it will flash on momentarily. Are these controlled by some type of ballast? Thanks
  • [ElectriciansForums.net] 3 of 6 GX24Q-4-pin type pots lights went out together any ideas?
Yes, if more than 4 years old, those are compact fluorescent lamps with an external ballast.
There are replacement lamps with the same base that are LED and require that you bypass the ballast (rewire the lamp). If I had a bad lamp or a bad ballast, I would replace it with an LED. You can find them on ebay and amazon, as well as other dealers. But be extremely careful to make sure you are getting a bulb that will fit and meets your needs. Also, you need to know how to wire it. It isn't a simple plug-in replacement.
If they all stopped at the same time that possibly indicates a poor connection.
House is 6 years old, so would the ballast be by one of the three that went out I hope?
Reply to 3 of 6 GX24Q-4-pin type pots lights went out together any ideas? in the DIY Electrical Advice area at ElectriciansForums.net
Hope everyone has had a great Christmas and here’s hoping we all have a better new year coming our way ! Remember our riches aren’t measured by...
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
You as well! Popcorn and beer on hand plus a day off, I'm ready! :)
My experience with commercial lighting is when the fixture is ordered or bought the specs should say 120/277. Then their wiring diagram should be...
