Hi, quick question about 3 phase 4 wire systems.
If I was wiring a single TP+N board all circuits running 230v very and well balanced and had a max load of 234A / 3 = 78A per phase.
So removing all correction factors and sizing the connection tails a wire size of 16mm br/bl/gr/bl should be sufficient?
The main question is can the neutral wire also be 16mm as the loads are balanced and neural should be zero current?
