Can a dodgy electric supply cause a TV fault? | on ElectriciansForums
Discuss Can a dodgy electric supply cause a TV fault? in the UK Electrical Forum area at ElectriciansForums.net
KevHardy
Southampton
Hi, turned on (LG) TV this morning and got a 'Select Item' screen and the volume graphic flashing constantly. The remote works and you can select menu items but it returns to the 'Select Item' menu shortly after.
I looked online and some suggested faulty power or HDMI cables, so I detached everything except the power cable. Same fault.
We have a smaller LG TV in the bedroom which was working so I put this in the lounge but got exactly the same fault. Which made me think it's not the TV but the power socket.
To confirm this I returned the smaller TV to the bedroom and the fault disappeared. I then took the large TV from the lounge off the wall and plugged it into the bedroom and the fault disappeared too. So it's definitely not the TV.
I ran an extension lead from the bedroom socket to the lounge, thinking this would solve the issue and confirm that it was the socket, but got the same fault.
I am now out of ideas. Could there be a voltage issue of some kind? I'm not an electrician so this is alien territory for me.
Are you trying to watch terrestrial through an aerial or sky tv from a dish?
It may be local interference, or a problem with any wiring.
Actually…. Try changing the battery’s in the remote… or take the battery’s out and manually change settings. (Either buttons on the set, or some TVs can be controlled by a phone app)
Have you got a sound bar which could be interfering ?
Reply to Can a dodgy electric supply cause a TV fault? in the UK Electrical Forum area at ElectriciansForums.net
Merry Xmas to all :D
    • Friendly
Thanks so much for sharing this with us! I’ll definitely take a look, it seems like there are a lot of useful and interesting products. The idea...
When I was at college doing the 2361 back in the 1980's I still recall to this day the instructor (Mr Wood) saying "Lads I do not want you to...
There could also be a completely unsuitable junction box embedded within the wall and tiled over or just cables in choc blocks in old accessory...
