3 phase fault | on ElectriciansForums
Discuss 3 phase fault in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
B
beaver74
hi all
i have just left a property where the RCD was tripping
when i got ther I found that it is a 3 phase T.T supply with 2 seperate boards
the intake has a metal switch fuse (even though it is a T.T)
tested L_N 230V..........L_E 340V
tested Neatral ant consumer unit and got a good reading. but the ron is warm to the touch so I would say it is carrying current
Any ideas
Beaver
post does not make any sense to me, (what is the "ron")?
Please do try to spell properly, if you like help.Posts that are so difficult to decipher as this takes a bit more time,than most of us have.
However if you would have said, the job is on the KLINGON home-planet, then i would imagine somehow it would be answered.
Have you put a clamp meter on the "ron"?
Could very well be an imported fault if there's properties near by. I would suspect a N>E fault on you intake or near by.
I'm trying to imagine how much current would need to be flowing through the 'ron' or the rod to make it get warm. Something doesn't sound right and I would be very cautious.
If its a 3 phase TT system i would suspect your earth is a bit high This would explain the low L-E voltage being low and the heat generated in the ear ron.....oops Rod
Reply to 3 phase fault in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Given that a lot of EV's only charge from one phase when connected to a 3 phase chargepoint does the customer really need a 3 phase chargepoint...
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
