3-phase installation | on ElectriciansForums
Discuss 3-phase installation in the UK Electrical Forum area at ElectriciansForums.net
Bertybert
London
Hello,
As part of unlooping the DNO has installed 3-phase domestic supply. My supplier has installed a 3 phase meter as well.
I believe I now need to have a 3 phase distribution board installed?
Can any of you guys know how long this would take at all? I do not know what hardware is required?
It would be prudent to install a new CU as well, as the current one is 30 years old.
Thank you for your consideration.
You don't need to have a 3 phase D.B installed, you can still just have a new single phase one, unless you have sufficient load / circuits to justify it.
I believe the DNOs installing 3 phase supplies are / will be the standard in future.
With what fuse rating per phase? If it's only 25A, keeping the max power to about the same as before, this will cause its own problems.
I'm more concerned about all the destroyed neutrals!! At least at the moment the DNO's can have limited control over phase balancing, install 3ph all over the place and you've lost that control. Add to that the increasing issues with SMP's and it's a recipe for disaster. There's also the challenge of limiting the pfc in a domestic setting even if the incoming fuse is only say 60A it's not hard to go into the 6+ kA bracket.
Reply to 3-phase installation in the UK Electrical Forum area at ElectriciansForums.net
I'm assuming the cable will have to be cleated well to hold it in place anyway, as a stuffing gland ain't going to hold it tight like a SWA gland...
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
