wouldn't bother, if it does generate anything it will probably be just enough to cause you a bit of a shock, you would need inverter equipment to correct the frequency, and the voltages would be of no use, not to mention that the blades etc are not designed for that....
you might be able to charge a few car batteries via a charger circuit using a vehicle alternator but it would take a while and only be usable through a sinewave inverter or just for running some small lights or a radio directly from a battery after charging...
