3 Phase Motors Speed Control | on ElectriciansForums
Discuss 3 Phase Motors Speed Control in the UK Electrical Forum area at ElectriciansForums.net
J
Jamie3032
Hi, Does anybody know of any alternative to governing the speed of a 3 phase motor than a frequency inverter? Thanks in advance, Jamie
I guess if it doesnt involve T+E you fellas are banging your head against the wall, thanks for the comedic replies though, just amazing....
If it,s a "bog standard" asynchronous induction motor (most common 3-phase motor) your meaning, a frequency converter is the only practical method. There is other more specialist 3 phase motors that can be controlled by other means but these are not very commonly used. Frequency converters are by far the most common way of controlling the speed of an AC 3 phase motor.
Noticed you got some really,really funny replies. Lol
Thanks, yes this is what I thought was the case, i am thinking that the frequency inverter can be controlled via a panel mounted potentiometer
You can control them via a potentiometer yes but depending on the make/model you can get a range of operator panels to give them better control and feedback on key parameters. Is the motor existing or to be sourced?
The motor is already in place D.O.L. , the budget is the main issue here, I wouldnt think that there will be any need for feedback or any kind of ramping up/down of speeds, just a means of governing the speed of the bandsaw blade for cutting different materials
Yes it can easily be controlled via a potentiometer and since the motor you want to speed control seems pretty small, and budget is important to you, I would think it would not cost more than a couple of hundred pounds to source a suitable VSD.
Reply to 3 Phase Motors Speed Control in the UK Electrical Forum area at ElectriciansForums.net
Hi James, At the inverter end the multi strand is ferruled and torqued in the terminal and at the motor end they are the “wago type” push fitting...
Came across 3No 1ph heaters connected by 2xT&E cables from a 3phase supply on an installation whilst carrying out an EICR few years back...
