dgrande
Hi, We recently bought a new pizza oven to replace the old one, it is a 3 phase and has a 5core cable coming out of the back of it (3 browns 1 blue and 1 earth g&y), the problem we are having is that 2 brown cores are connected together and the other 2 blue & brown are also connected together. How does this connect to the existing 3 phase and neutral isolator switch? I was thinking that maybe it can also use a single phase supply and therefore the cables were joined in pairs, do I have to undo the pairs that are joined and connect the 3 browns to the 3 phases and the blue to the neutral and if so do I need to open the oven and changing internal wiring connections?
Also this is a 16kw oven running from the DB on a 3 pole 63amp fuse, is this size fuse ok?
I have only worked on single phase and not have much experience on 3 phase. Your help will be appreciated.
