Can i install a new circuit or do minor works on a plastic consumer unit under the stairs which is the only escape route. | on ElectriciansForums
Discuss Can i install a new circuit or do minor works on a plastic consumer unit under the stairs which is the only escape route. in the UK Electrical Forum area at ElectriciansForums.net
Tumber92
I know it's only a C3 but I've been to quote jobs where previous electricians have told the client that they have to get it replaced to comply with current regulations which is false and basically scaring the client to get more work. I'm pretty sure that's not the case, as its only recommended. My apprentices tutor is telling him it's a C2 and any work done on the DB has to bring the current DB up to current regs (basically replaced with metal CU). Just because it's plastic and under thr stairs doesn't mean it fails the property on a condition report. I phoned the niceic and they have quoted saying that it is only a C3 and can be worked on provided it's still in good condition. What's everyone's thought on this because everyone has their own regulations it seems.
Providing the Consumer Unit is in Good Condition and no signs of thermal damage then just a note on the MWC that it is Plastic and recommended to be upgraded to Metal just like a C3 on an EICR. That way at least you are covered.
I don't think anyone on here is going to say it needs replacing, some may even argue that it's not even a c3.
Reply to Can i install a new circuit or do minor works on a plastic consumer unit under the stairs which is the only escape route. in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
