3 phase PAT adaptors | Page 2 | on ElectriciansForums
Discuss 3 phase PAT adaptors in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Surely 110v 16A plug & socket are single phase, therefore your extension leads made up with these are tested as a "230v" extension -except in 110v mode.
yes, that's how my test leads are made, 13A Plug to 110v 16A socket L-L, N-N, E-E but the point I was trying to get over was that in the 3PH test plugs they have removed the live so you can't attempt to power a 3PH device from a single phase but in a ready made 110v test lead do they do the same because you could plug a 110v appliance into the test lead and give it 240V.
my test leads are clearly marked up for PAT only and I wouldn't let anyone else use them but the danger is still there.
Reply to 3 phase PAT adaptors in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi all, We have a limited in house PAT testing requirement and were advised that the TIS700 fitted our needs. The unit works fine for 110V and...
what is the piece of equipment and part number?
