3 phase regs in proximity to swimming pool | Page 2 | on ElectriciansForums
Discuss 3 phase regs in proximity to swimming pool in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
https://electrical.------.org/media/1706/swimming-pools-no-need-to-make-waves.pdf
and see page 17 of 36 of
https://electrical.------.org/media/1055/2012_42_spring_wiring_matters__complete_adverts.pdf
and table at 2 of 4 of:
https://electrical.------.org/media...special-installations-or-locations-part-1.pdf
There should be some guidance in these (or later IET wiring matters pieces).
I googled 'IET wiring matters swimming' and 'IET wiring matters special locations'.
And here is Guidance Note 7 for special locations:
Guidance Note 7 - Special Locations - https://electrical.------.org/wiring-matters/issues/33/guidance-note-7-special-locations/
Reply to 3 phase regs in proximity to swimming pool in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
