View the thread, titled "3 Phase Supply, Need A Seperate Earth" which is posted in Electrician Talk | All Countries on Electricians Forums.
you can get them upto 95mm,don't no why companies can't read cataloges .iv'e just put a 70mm 4 core in with 6.0cpc (computer say's so)computers can't read cat.either
yours benji
6.0 mm seems a bit on the lite side ,are you sure its correct:confused:
looked at the cleveland cable site ,yes they do 25x5 core but its got a 25 mm earth
running a seperate 16mm earth would be cheaper
yes 6.0mm does look small ,but comp. calc. prog.say,s its ok,it looks crap but we have elec. designers who do all the calcs. for us?
i would sooner install a 5c25mm than a 4c +16.0cpc ie only one cable to pull &only one to g&t
yours benji
the installation costs would be the same as you can generally get away with installing the swa and earth at the same time
that just leaves the price per metre of 25mm 5c swa versus 25mm 4c swa & 16mm earth
Thats what I ment it will cost more to run a 5-core swa than 4-core and seperate 16mm cpc
Without knowing the full facts I see that no mention has been made of making the remote supply TT. This has the advantage of not requiring a CPC. The Swa is broken on entry to the remote building and is bonded at source. RCD protection is of course required and an earth stake.
Reply to the thread, titled "3 Phase Supply, Need A Seperate Earth" which is posted in Electrician Talk | All Countries on Electricians Forums.
