3 phase supply no neutral how do i get neutral for the contactor coil?? | on ElectriciansForums
Discuss 3 phase supply no neutral how do i get neutral for the contactor coil?? in the Australia area at ElectriciansForums.net
A
aldomack
Hi I wander if anyone can help?
I have just wired up 2 3 phase motors on a Farm for a Auger System, I have ran in a 3 phase supply from a nearby J.B. There is only 3 phase wires and the outer armour of the cable connected to the body of the box as the earth on the J.B. I have run these into the Control box for the Auger and connected the earths up and the Phaes L1,L2,L3. These are going into the top of the breaker, BENEDIKT JAGER K2-09A. There is connections for the contactor coil A1 and A2, I require a neutral for the coil to work but how do I get this when there is none on the supply I have run??? hmmm I'm stuck:(
please see attachment
[ElectriciansForums.net] 3 phase supply no neutral how do i get neutral for the contactor coil??
Here are somre more photos, the incomming supply comes in from the left and into the top of the right contactor, the 2 contactors are linked at the top. The Motors are fed from out the bottom of the contactors,
  • [ElectriciansForums.net] 3 phase supply no neutral how do i get neutral for the contactor coil??
Reply to 3 phase supply no neutral how do i get neutral for the contactor coil?? in the Australia area at ElectriciansForums.net
