3 Phase supply
Not read all the posts but apply to the DNO for a Ryefield cut out and then each tenant can apply for their own meter. If I was renting a unit, then I wouldn't want the landlord or other tent ants dictating who I buy my electricity from.
The op has only got an 100amp 3phase supply, the dno will not fit an multi way on that, unless the supply cable is big enough for upgrade.
You'll be screwed on a lot of small industrial estates then! Lots of them have a single supply and sub-metering in each unit.
sparkyste1,
davesparks,
