shawn p
I have a 3 phase washing machine looking to install on a single phase supply.The machine is 13.30kw,what is the best way to install,
Ask my electrical supplier to change my electric to 3 phase just needed in the garage so does whole house need to be changed ?
Run a 16mm swa from my main feed to the garage and then a 14kw 3 ph to 1 ph converter :very expensive.
im informed that this machine can not be converted to single phase as is one of the only machines that can not be a IPSO WE 165.Does this apply to both the motor and heaters or can the heaters be changed to single then needing just a converter to run the 3 phase motor ?
im not an electrician so will not be conducting any of the work just need a cost efficient and reliable way to power the machine thanks
