Search the forum,
Discuss Wiring for single phase supply in the Commercial Electrical Advice area at ElectriciansForums.net
Logie
Looking to use this brooks Compton motor as a replacement in an electric cement mixer. can anyone tell me if it is designed to operate off a domestic single phase 240v supply? It looks to me as though it could run off either a single or threes phase supply but I’d be grateful to hear from somebody who really knows!IMG_1503.png
Picture isn't clear but from what I can make out that is three phase only. 220 -277v in delta and 380-480v in star.
This is the same format nameplate, but different motor, (didn't realise how many times Brook had changed the format)
All you need to know in the bottom left corner of the plate, both are 3 phase.
You need a motor with 1 in that box
Reply to Wiring for single phase supply in the Commercial Electrical Advice area at ElectriciansForums.net
Absolutely losing my brain here guys What I would like to be able to do is power our 3 phase motor on a single phase supply. Thought I had it...
I have a single phase stainless steel pasteuriser that has two control boxes attached to it. One box houses the control for the electronics and...
Hello all, I signed up here for a little help. I bought a 3 phase bandsaw and went down the rabbit hole of VFD’s etc. ‘The motor is 3 phase 400v...
hi Can anyone tell me where to wire the active and neutral wires to in this single phase electric motor
Hi, As a DIYer I`ve quite a bit of wiring up domestic house single phase experience but no 3 phase experience. So I have been offered a two post...
