3 Phase Wire Colours on L1 L2 L3 Single Phases | on ElectriciansForums
Discuss 3 Phase Wire Colours on L1 L2 L3 Single Phases in the Talk Electrician area at ElectriciansForums.net
C
Chris_1969
Hi all,
I am looking at a system that is supplied with a 3 phase supply and into a cabinet. Then external to the cabinet L1 and Neutral feed unit one, L2 and Neutral feed unit two, L3 and Neutral feed unit three.
Units one, two and three are at a distance of 50 meters from the cabinet.
What colour must be used between the cabinet and each of the units? What reg covers this?
Many thanks,
Chris.
Hi Chris welcome to the forum.
Im not sure what you mean by units? unit 1 2 and 3 have been fed via each of the 3 phases to provide single phase power (230V)
If I am correct the cable supplying each unit will be of the new colours and that will come under the harmonization of cable colours regulation March 2004. Amendment No 2, 2004 of BS 7671:2001, This will all depend on when it has been installed as the old 3 phase colours were phased out by 2006. A bit more information would be helpful like what is a unit/cabinet and what cable is being used between the cabinet and units. With more information im sure a more experienced member will be able to help you.
The 3 phases l1 l2 and l3 would be coloured brown black and grey. Neutral would be blue.
The phases coming out sound as you have described as though they are going to 3 separate distribution boards which are single phase. Therefore they would be all brown with a blue neutral.
Hi all,
Many thanks for the welcome and responses.
The 'units' are pieces of equipment that are identical (production line testers) and are both powered and controlled by the single cabinet (that is fed by a 3 phase supply). There are actually 12 units and phase 1 from the cabinet is powering units 1,4,7,10. Phase 2 is powering units 2,5,8,11 and phase 3 the other units. This is new equipment just waiting to be installed.
A 17th edition guy has specified that we can use the 3 phase colours to wire the units. So before we do I would like to check and have something I can evidence.
Many thanks,
Chris.
As others as said if you are runnig singles phase circuits regardless of comming from a 3 phase board or a singles phase board the line conducters should be brown and the neutrals blue , i think it was back in the 15th addition that you could use the red yellow and blue phase colours for single phase circuits.
It was never allowed for final circuits - only distribution circuits (or submains as they were then known).
who were we harmonizing with
Good question.
I came across a British guy who was building a new house in France. A quite large new house with a three phase supply. It was after the new harmonised colours became mandatory for new installations. He was using red, yellow, blue, and black.
If were cynical I'd say he was using UK cables that had to be disposed of because of the new regs.
Reply to 3 Phase Wire Colours on L1 L2 L3 Single Phases in the Talk Electrician area at ElectriciansForums.net
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
4K
Three phase or single phase it is not correct.
