3 phase | on ElectriciansForums
Discuss 3 phase in the Australia area at ElectriciansForums.net
stewart1980
hi there i am starting my own company and i have just bought a new tyre machine my unit has single phase but the machine is 3 phase with 4 wires black blue brown yellow and green on the side of motor it has v-220/380 now can i use this in my unit and if so how do i go by doing it please help as losing money now with it not working
Hi Stewart, in short you're out of luck. There are things that can be done to produce 3 phase from single phase but they're highly unlikely to be cost effective at your scale and well beyond giving advice over the web.
Your two best options are 1) see if you can replace it for a single phase machine and/or 2) talk to your energy supplier / unit management about getting 3ph installed, which won't be cheap either.
Either way, when it comes to wiring anything in, I strongly suggest you get a reputable qualified electrician in to do it for you - have a search here for your area.
The 3 phase machine will not run off single phase
You have a couple of options
Convert that single phase to 3 phase with something along these lines STC1.1KW Static Single to Three Phase Converter 0.75W/1.0hp ,(depending on the size of the motor)
Replace motor with a single phase of the same type
Give it back and get a single phase replacement
What does it say for frequency on the motor plate?
In which case, I take back what I said! If it's only that small, then one of the units that Des suggested may well work for you.
Reply to 3 phase in the Australia area at ElectriciansForums.net
Think all has been covered already, but echo-ing the above if I was getting my DB swapped and had a 3 phase head, I would put a little TPN board...
This UK company seem to sell parts for them so it might be worth contacting them after that you could try the manufacturers La Rocca | Máquinas de...
