3 way Connector for LED strip | on ElectriciansForums
Discuss 3 way Connector for LED strip in the Lighting Forum area at ElectriciansForums.net
Josh2025
8wSB8xQkB9hzYNY
Is it possible to get a T / 3 way connector for a
COB LED Strip White CCT Tunable 10 mm wide 3 pin?
I wan to connect the strip to port A, Led to port B and extension electric wire to port C with another lenth of the strip at the end of this wire.
maybe I'm making this too complicated?
Thanks,
[ElectriciansForums.net] 3 way Connector for LED strip
You can solder wires for your tee connection at any of the copper pads along the strip. Slide on a short length of heat shrink to serve as a cable clamp.
Reply to 3 way Connector for LED strip in the Lighting Forum area at ElectriciansForums.net
Hi all, I have a couple of questions I'm hoping you can help with. I have put a solar panel on my kids play house which charges a 12v battery. I...
