3 way gang switch Led bulb still lights when switched off. | Page 2 | on ElectriciansForums
Discuss 3 way gang switch Led bulb still lights when switched off. in the DIY Electrical Advice area at ElectriciansForums.net
Ignoring all the wiring in the switch (which I assume you have not altered), this is a common problem with LEDs and is due to induction between a line and switched live cable. The usual fix is to put a snubber (capacitor and resistor in series) across the LED.
https://uk.farnell.com/roxburgh/xe1202/rc-network-250v-0-2uf-120r-pcb/dp/2336099?st=snubber
What are you trying to say, @GeorgeCooke ?
I think a mod has some duplicate posts to delete.
I’ve got an LED fitting to look at after Xmas in a neighbours house, and this thread has the same problem:
It’s on the stair landing so is controlled through a 2 way circuit. 2 switches. The problem is that the light stays on dim when it should be off, but only when the switches are in a certain configuration. Ie
Switch 1 off, switch 2 off..... light off
Switch 1 off, switch 2 on..... light on
Switch 1 on, switch 2 off..... light on
Switch 1 on, switch 2 on..... light dimly on(should be off)
So likely an induced feed onto one of the strappers in the 3 core+ earth cable. (Newish build, I know it’s wired in flat grey)
I might get one of those snubbers and see if it works.
Reply to 3 way gang switch Led bulb still lights when switched off. in the DIY Electrical Advice area at ElectriciansForums.net
Loose neutral somewhere… possibly at panel or at the last light before it goes to panel. You say you’re getting power through the switch and up...
You as well! Popcorn and beer on hand plus a day off, I'm ready! :)
