3 way switching relay | Page 2 | on ElectriciansForums
Discuss 3 way switching relay in the UK Electrical Forum area at ElectriciansForums.net
Essex
Hello there,
I'm in a situation whereby the customer wants a light switch either side of the bed, and one by the door to control the centre room pendant. Unfortunately the type of switches they have across the rest of the house doesn't produce an intermediate switch.
Does anyone know any off the shelf relays where by I can use one or two way switches to solve this?
Andy
If appearance isn’t an issue now;
LightwaveRF.
Smart switch that doesn’t require a neutral (but does need a filament lamp as the load rather than LED) in place of bedroom switch. Battery operated remote switches either side of bed, both paired with the wired Master switch.
Other smart switches are available that could do the same job.
And now we're back at the original problem. Does anyone know of a 2 way pull switch ?
Yes. Just about every lighting pull switch is 2-way. Even Screwfix sell them!:tongueout:
pedant warning. Yes I know DP switches aren’t 2 way, and I expect you cannot buy 2-way pull switches in Poundland. Etc.
Well I never, never thought there would be a demand for one! I guess you could have a pull cord over the bog in case it gets dark whilst you're there.
Reply to 3 way switching relay in the UK Electrical Forum area at ElectriciansForums.net
Furthermore, as the left hand switch will currently not do anything, I'd try the loose brown in here:
Hello freddo (and everyone else who commented!), Thanks for your comment. Using that info, I now have this on the main: and this on the...
