New range on the way and took our the old range (about 2010 install) that was hard wired in with 2 hot wires (black and red) and a green ground wire that was attached to the neutral wire post on the old range.
diagram for new range says that 3 wires should be red & black hots along with a white neutral. the ground wire is added for a 4-wire installation and is attached at the neutral wire slot with the white neutral wire. This original 3-wire (no neutral) worked on the old range for about 10 years, but I'm wondering if someone cut corners in the last installation that I should be concerned about now? Can I screw the ground into the neutral/ground connection without a neutral wire and not worry about some possible impending doom I am opening us up to?
