3 x 2.5mm T&Es into one 13A socket. How do you do it? | on ElectriciansForums
Discuss 3 x 2.5mm T&Es into one 13A socket. How do you do it? in the UK Electrical Forum area at ElectriciansForums.net
Mark42
Patron
UK
I've always disliked needing to wrangle three 2.5mm T&Es into one 13A socket.
The three solid cores rarely sit cleanly, and there's always the suspicion that at least one core is not being held properly:
[ElectriciansForums.net] 3 x 2.5mm T&Es into one 13A socket. How do you do it?
Lately I've been doing this, using 5-way Wagos and bits of stranded 2.5mm single, fitted with ferrules, into the socket itself:
Of course that's more joints. Perhaps unnecessary joints. But it appears to me a more secure and more maintenance-free method.
I don't believe there's any regulatory reason why it can't be done like this.
What do others do/think?
Seems like a lot of work for a problem that doesn't / shouldn't exist.
The only time I've had that issue is when refitting very cheap sockets where there isn't really enough space for the 3 wires or they have been cut too short and my fat paws won't fit.
It does mean less risk of things being disturbed when the socket is wraggled on to the back box. And the stranded singles will make things easier. As above though, quite a bit off faffing.
Be interesting to see what people think.
Why not just use the
MK LOGIC RAPID FIX
Aren't you technically taking two spurs from one point of the ring though?
IE you have ring in and out, plus the third to your spur - but then the socket its behind is also a spur - as the point of junction is now the wagos rather than the socket faceplate
I agree, he's turned the existing socket into a spur.
Effectively picture #2 is what they do in America / Canada called PIG TAILING , they do it a lot over there using Wire Nuts to bind all the cores together in the back of the box and just take a single cable to the socket or as they call it the receptacle.
Most sockets will take 3 x 2.5 cores , except for the really cheap carp ones
never had an issue before... not with new, clean solid core. As you tighten the terminal screw, the cores will turn so the screw is gripping two cores, and the other is pressed into the back of the hole.
Never twist together.
stand by for other manufacturers following MK..... Still not used one yet, but i can see it being a time saver if fitting out an entire house.
Will you be going back to the jobs to correct them ?
Ridiculous in my honest opinion
Reply to 3 x 2.5mm T&Es into one 13A socket. How do you do it? in the UK Electrical Forum area at ElectriciansForums.net
