Hi Fellow Sparks. I have to install a 30 metre run of Main Protective Bonding Conductor to Gas Main and Water Main in a commercial building. Is it permissible under the IEE Regs to clip a single 10 sq.mm PVC cable directly to the building surface for this, or should it be enclosed? Also, is it permitted to use one conductor for both Gas and Water as long as the first termination is unbroken at the earth clip? Cheers - Les
