sparkysean
Hi guys I'm installing 2 new circuits for a 30A hob and 30A cooker. I'm drilling holes through joists and clipping direct, the cable run is around 25m each, i'm going to use 4.0mm? We all agree this is ok?
Discuss 30A induction hob and 30A oven in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
you said in your op it was 30A, not 3kw, so i used 30A. max. volt drop allowd is 5% or 11.5v so you will be ok with 4mm.@ telectrix how did you get 7.8v, how did you find current?
Reply to 30A induction hob and 30A oven in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
