30kw boiler cable calculations | Page 3 | on ElectriciansForums
Discuss 30kw boiler cable calculations in the UK Electrical Forum area at ElectriciansForums.net
M
meggerlover
Hi guys just a quick check in my calculations for a quote I'm doing
15meters clipped direct
30,000w divided by 400v
= 75a per phase
im using sy cable and think 16mm 5 core is best
What you guys think
Megga im still curious is this a domestic or commercial boiler , would think domestic at that size ?? thats why i asked about the 16mm seems huge
As a gas fitter you are probably thinking of the boiler's size in terms of heat output, expressed in either kW or btu. A 30kW output boiler would be common in a domestic house. The calculation being done here is for the electrical energy (input) being drawn by the heater, in this case 30kW. In comparison a household kettle would draw about 2.2kW.
Your previous question about cable size ...... cable is measured by the cross sectional area of the conductors. 16mm is actually 16mm squared. It doesn't relate to the diameter of the cable as a whole.
Cheers andy
You guys should be gettin paid to teach on here lol, i find loads of guys claiming to be sparks on here but need to ask you guys for all the info,
Next door in plumbing forum unless they prove they are gassafe reged then we simply cant help them lol
Unfortunately we have no such similar scheme. The only schemes we have drag people off the streets, take their money, tell them they are electricians, and devalue our trade. All with the full backing of the govt.
= 75a per phase
What you guys think
I think the "NO" vote has confused you.
Heard of:
Power = sqrt(3)V[SUB]L[/SUB]I[SUB]L[/SUB]cos(phi)
Rearrange to get I[SUB]L[/SUB]
See, it's not that hard, is it?
Reply to 30kw boiler cable calculations in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
