30kw boiler cable calculations | Page 6 | on ElectriciansForums
Discuss 30kw boiler cable calculations in the UK Electrical Forum area at ElectriciansForums.net
M
meggerlover
Hi guys just a quick check in my calculations for a quote I'm doing
15meters clipped direct
30,000w divided by 400v
= 75a per phase
im using sy cable and think 16mm 5 core is best
What you guys think
are you serious
kopex goes upto 75mm
[ElectriciansForums.net] 30kw boiler cable calculations
So have you already bought the cable then ?
I'm confused.. post 1 says you are pricing for a job and want your calcs and cable size checking.... then you said you bought the SY because it's all that was available.
Reply to 30kw boiler cable calculations in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
