brucelee
Hi all
I know that ovens have to have own supply over 2kw
I have a question on a electric oven and gas hob with ignitor on 0.75 flex so i thought 16A breaker to a 20amp dp switch and double socket but after having a look at the job and oven i found wattage of oven was 3250watt so draws 14.13amp
I am now thinking 2.5mm t/e cable, 16amp breaker, 20amp dp switch and flex outlet the oven is not wired with a flex but manual says three core 1.5mm Hov5 V-F flex, also need a socket for the ignition of gas hob which i may now do off a sw/f/spur to low level socket is this ok any advice please chaps or suggestions of a better way
