32A mcb changed to 40A mcb what certs? | Page 2 | on ElectriciansForums
Discuss 32A mcb changed to 40A mcb what certs? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
As its in the bathroom it should be on RCD protected and it is RCD protected. Lose connections are the usual suspect for burning cables but if Triton says 40A I do 40A.
That's fair enough Rigby. ...When all said and done, this is your job and you hold the responsibility for your work!!
Reply to 32A mcb changed to 40A mcb what certs? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
I generally thought double stack boards were more for situations where a portrait design is better suited to the cupboard - you still generally...
It’s quite common for an electrician to criticise another’s work as you will rarely get everything perfect.
