32mm Holesaw in Metal Consumer Unit knock out - balls up! | on ElectriciansForums
Discuss 32mm Holesaw in Metal Consumer Unit knock out - balls up! in the Talk Electrician area at ElectriciansForums.net
N
Noob2013
Hi all,
I was dreading drilling a 32mm hole in the top of a Hager metal Consumer Unit for a 25mm Swa. There are square knock outs all along the top and my worse fear was the knock out coming out.
Anyway, there is limited room so I had no choice but to terminate the swa in the consumer unit.
I started drilling the hole and all was fine until the very last bit - the knock out came out!
So I now have one of the square knock outs in the top of a hager board missing with a half circular hole.
Possible due to lack of experience but how can I gland the swa now?
I was thinking I could have a square piece of metal either side of the costumer unit with a 32mm hole in each to fix it securely.
Any ideas much appreciate
I don't have an answer but have been pondering this one too!
Shame the CU manufacturers don't have answers and more shame to the IET for implementing such a stupid reg
I think, if possible I'd take a jig saw to the top of the CU and take out or put as big a slot in the top as I could and then plate it with some metal sheet, maybe cutting something like a piece of trunking or adaptable box lid. then terminate the armoured into it and possibly slot the rest for any sheathed cables. Just be careful you get rid of sharp edges, grommet strip or maybe piece of Truflex? and make it look as good as you can? Barrie
Cheers for the advice.
I think I'll try the idea me and Leesparkykent had with use a piece of metal.
I just had a thought, the large oval knock outs I took out for rear cable entry are big enough and will look better as they are the same colour and finish as the consumer unit
Yep, plate it (and maybe put some high temp sealant around it).
Won't help here but the newer Contactum boards have 32mm knockouts on both sides (top right side and top left side) and also on the bottom right and top right. Not a recommendation as I don't like the fit of the front, but for future ref.
Have not fitted CU for long time, why the hell are knockouts square.? square terminations these days.? lol
For mini trunking entry of cables, perhaps?
For me make a new plate and pre drill this so fits nicely over balls up and your glans holds it all together !
An interesting turn of phrase you have there ! :eek:mg_smile:
Reply to 32mm Holesaw in Metal Consumer Unit knock out - balls up! in the Talk Electrician area at ElectriciansForums.net
