37 kw industrial oven | Page 2 | on ElectriciansForums
Discuss 37 kw industrial oven in the UK Electrical Forum area at ElectriciansForums.net
M
melvinmoo
hi just to check my sums are correct I will be running my oven of a 60 amp 3 phase breaker as the oven draws 51 amps I will be using a 5 core 10mm swa lsf cable to a 63 amp commando skt outlet does any one have any issues that may have missed any advice welcome
Please don't go there on a warranty issue, heard it all before, that is just pure scaremongering!! Any approved means of connection to a fixed supply (eg, switch fuse / switch isolator /plug & socket etc) that is recognised by BS7671 and you won't VOID any warranty. Double indemnity if the person making the connection to the supply is a qualified electrician!!
Reply to 37 kw industrial oven in the UK Electrical Forum area at ElectriciansForums.net
