T
T0RN4D0
Hi, im new here. Looks like a pretty active forum so i'm hoping someone can help me maybe.
Here's my problem. Neighbor just bought a used circular saw with a 10kW 3ph motor on it and asked me to rewire it, because the cable from the started switch to the motor box was all messed up.
Anyways, the delta star switching is done by a simple 16pole switch. First time around i marked all the connections and just duplicated them with the new wire. It worked in star, but the fuse tripped when i switched to delta. I then searched for the switch schematics, took everything apart and wired it according to that scheme. Still, same thing. He only had a 16A fuse, so we changed it to a 25A, didn't help.
I marked where i wired everything and tripple checked it, i think its right. I think i have a problem with phase sequence somewhere, but i'm not sure where and which wires to change.
Any ideas what could be wrong, and which wires i should change to make it work? The input phase sequence (L1, L2, L3) doesn't matter, or does it in this case?
