View the thread, titled "3ph delta star switch, delta tripping fuse" which is posted in Commercial Electrical Advice on Electricians Forums.
You'd have thought the bump tests non loaded would be second nature to an electrician?! I had this drilled into me over and over again when I was an apprentice! "Bump in star, check rotation!", "bump in delta, check rotation again!".
The OP is a student in Energetics? ... not an Electrician which is a bit worrying as although he seems to have a grasp on rigging this saw he lacks knowledge of safe procedure commissioning and faulting which is essential knowledge for his own safety and of others and also having connected it up he holds responsibility that it is safe to use ....judging by the manual star/delta we can only assume the saw itself is also many decades out of regulation but as im not from Slovenia i can't comment on their standards.
My response was mainly aimed at Tony DW. The fact that he feels the need to remind people to check motor rotation before attaching the load tells me that he has lost much faith in the current standard of electrician! lol.
The thought that there are probably many people out there who would simply forget this most basic yet most important of tasks worries me!
They just don't train people properly anymore.
Ive learnt more off one guy in the last 2 months than from the rest of the firm in a year.
Another tip,when installing a machine which you are unfamiliar with,make sure phase sequence is correct at the machines incoming terminals then get someone who knows how to operate it to start it up,that way there's no chance of being blamed for any damage caused by operator error.Yes we know how to connect machines up but operating them can be expensive if we don't know how to do it correctly.
- - - Updated - - -
Straight out of the University of Life that one! And their course; C&G 2397 - Certificate in the employment of passing the buck techniques.
:D
The trouble is, it's quicker to take shortcuts.
I still think this is a 'home made ' jobbie! I also fear that it doesn't have the basic safety features we take for granted found in control cct's. such as 'overload' and 'no volt' protection, electrical and mechanical interlocks, etc the list goes on!
I once worked on a single phase planer that was built in Slovenia, It's control panel consisted of an on/off switch, forward/ reverse switch and thermal o/l unit and nothing else!
OP: You should be able to switch to delta as soon as the motor is nearly up to speed. A circular saw starts unloaded so the starting duty isn't very demanding, apart from the inertia of the blade. If you have to wait longer before switching, without the motor speed increasing, then there is a fault. Check the current in each of the three lines when running in delta to confirm that all three phases are functioning correctly - they should all be very similar. An oversized motor can sometimes carry on running with a supply phase out, although it will eventually overheat, especially if you don't have proper overload protection.
However, more than anything else, I would say that in these enlightened times running a circular saw without no-volt release is unacceptably dangerous. Never mind the fine details of electrical safety, the possible consequences of a sawbench starting up without warning are serious!
Forgive me if I'm being a bit blind but I can't see anywhere where the OP has indicated that there isn't a no-volt release. It's running via a standard YD starter.
The whole unit was home made. Regulations are not a problem because there basically are none when it comes to what you're using at home. And yes, there is no no-volt release and no motor protection. I think it might be worth adding it.
I didn't check the current on all phases, would be easy enough to do. Did check the voltage on all three phases (only had a DMM with me) on the motor clamps and that was fine, but i guess that doesn't matter if there's a problem with one of the windings.
Is it possible that the breaker is so close to the limit when starting it needs a few seconds to "cool off" before its able to go through another over-amp jolt when switching to delta?
Reply to the thread, titled "3ph delta star switch, delta tripping fuse" which is posted in Commercial Electrical Advice on Electricians Forums.
