Hi all, I would like some advise on a job i am about to undertake, A large industrial unit being used as an mot garage with an incoming 3ph supply of 63A. The client has ramps and testing equipment which totals 97A (this is adding together the various A ratings printed on the motor plates of each piece of equipment) along with a ring final circuit and a good chunk of flourecent tubes this puts it at well over 100A. Im not sure of the diversity allowance on this kind of install but i know all machinery will not be used at the same time. I think Its going to be a case of having a bigger supply fitted but would like to know how to put the wheels in motion and how big i should/can go
Thanks in advance guys an gals
