3ph star delta starter motor drawing high amps | on ElectriciansForums
Discuss 3ph star delta starter motor drawing high amps in the Talk Electrician area at ElectriciansForums.net
Notts / yorkshire
Star delta starter / motor problem.
Starter starts runs as should on bench with no motor connected. Getting 230v to e on all 6 uvw 1s and uvw2. 415 u1 to v2 etc etc. But nothing 1 to 2s. As expected.
When motor connected up. (Single speed) it takes 3a in start on all . Drops into run fine but is taking 38a on all.
After 5 seconds it trips breaker.
Any ideas were to start. As both out of stores as spares and checking they work but now stumped
could be a few things, im no expert on motorwindings but when they lose balance tends to be when things go pete tong, was there a reason it was stored away no longer used or was it working last time it was tested?
[ElectriciansForums.net] 3ph star delta starter motor drawing high amps
Reply to 3ph star delta starter motor drawing high amps in the Talk Electrician area at ElectriciansForums.net
I got this all wired in and working thanks to the help from James, absolutely top man. Do have a small issue with current imbalance atm, L3...
