Three phase squirrel cage motors will have 6 ends at the terminal block, it's how they are connected that determines how they start and run.Hi yes we was testing separate items out of stores. So not knowing conditions of either item.
Motor was original connected to dol and ran fine.
Obliviosly links were took out to connect to 6 wire star delta.
Thinking must be delta contactor problem.
But just curious now as someone mentioned not all 6 wire motors will run on. Motor reminders confirm motor will run in either.
Anyway items been put back on shelf for another rainy day tidy up.
Thanks for everyone's help.
Using the Erroneous diagram , with K3 closed .This is exactly the mistake I presume it to be, should have read the comments before responding.
