Good morning
I need to fit a new 3 phase dis board in an annexe I'm building at my own house.
Usually I'd use SWA, or singles in conduit/trunking, but as the run is all in loft space and not liable to physical damage (no rodents), I'm thinking of using surface-clipped 5-core 16mm NYY instead, especially as there are some tight-ish turns, and space in the board it's coming from is also tight.
I can think of no technical reason why this is not OK. Possibly it's routine?
Any comments?
Cheers
Mark
Any comments?
Cheers
Mark
