3phase DB as single phase | on ElectriciansForums
Discuss 3phase DB as single phase in the UK Electrical Forum area at ElectriciansForums.net
newfutile
Nearly Esteemed
Supporter
hemel hempstead
It's coming out anyway so it's a rhetorical question.
What do you you all think of this?
Bits of wire used to bridge the bus bars and don't single phase consumer units need a linked switched line and neutral?
[ElectriciansForums.net] 3phase DB as single phase
Poor practice to have used cable and not bus bar due to the risk of overload, no requirement for interlinked switch to disconnect the neutral unless it's in a domestic-ish setting (462.1.201 & 463.1.2)
Have seen this done quite a few times where some off cuts of cable have been used to link across the main switch.
Like wise have come across a fair few domestic boards where the busbar has been lost and they have linked out the bottom of the MCBs in 2.5 cable
Hager also do a 4P incomer switch kit so you can have both the single-phasing kit and DP isolation if you do it right. Not like here!
But I do wonder WTF was anyone fitting such a small 3P board for SP use?
Ordered a 4 way board, without paying any attention to detail, and made the most of what turned up?
Edit: I can see 6 breakers, but liked the idea.
Could be. I did wonder after posting if it was anything to do with needing industrial levels of dust, etc, tolerance or even 10kA break capability.
Then I remembered the wires and clearly they were not design considerations...
Reply to 3phase DB as single phase in the UK Electrical Forum area at ElectriciansForums.net
Has the cover been removed, is it TP bussbar? I fitted one as @oscar21 linked to a few months ago, it was actually a nice board and with the TP...
Have you got the lid of the connection box on the motor? Often there's a wiring diagram inside the lid. What is the make and model number of the...
