+3v out of the ground wire?? | Page 4 | on ElectriciansForums
Discuss +3v out of the ground wire?? in the UK Electrical Forum area at ElectriciansForums.net
F
flatcat
Hi there
An oddity, here.
My horses and goats were dodging the water trough, which has a floating deicer.
Long story short, turned out the ground was putting out a little current. A tech guy from the deicer manufacturer said it could be a poor ground [this is in the barn, whose panel runs off a 30A line from the house a hundred feet away and is grounded by a rod], or could actually be coming from the power company. Some remark on the web said the latter also.
This was not happening last year.
Solution was a pigtail into the extension cord, with a separate ground rod.
But what the heck is this, and do I need to do anything about it generally?
Mostly curious.
Flatcat
It's all relative, if you find an experienced electrician with decent test equipment he'll take probably less than an hour to come up with a list of what needs doing and in what priority. Treating symptoms is going going to work out a lot more expensive and a lot of the work you do may be unnecessary.
I don't know what it's like up north but I stayed in Brunswick Ga for a couple of years and the local farmers would pay in meat for pump and machine repairs. Find a sparky who's happy to barter.
Things here seemed to be getting away from elec-tech and into the personal and antagonistic; not what I enjoy.
To answer the previous post, our dog buckets, for instance, have the heaters enclosed under the floor of the bucket; horse troughs use immersion heaters. I have no idea why resistance metal which is heating because a current is passing through it does not pass current into the water, but obviously by design they don't. Ask someone here for the theory.
When I observed the problem this year, first thing I did was assume the deicer was bad and buy another one; problem remained. Wasn't the deicer.
For the record, electrician came out today and found that both panels in the barn were poorly grounded (what I was pursuing). He corrected it. Found same thing in the house panel, and explained to me how to fix it.
I have also made an enclosure to protect the juncture between ext. cord and deicer, soldered the ground wire to the pigtail lug, and added a clamp to the trough ground rod, though the latter setup is presumably no longer needed.
Reply to +3v out of the ground wire?? in the UK Electrical Forum area at ElectriciansForums.net
Sorry for the late response but by the NEC code book requires one ground rod near the panel and another ground rod at least 6 feet or more using #...
Recommended Sponsor News
Hi everyone,
