4 mm Cooker circuit 32amp MCB | Page 2 | on ElectriciansForums
Discuss 4 mm Cooker circuit 32amp MCB in the UK Electrical Forum area at ElectriciansForums.net
just visited a customer who requires a 7.3kw hob connected to replace existing gas hob. Currently has a 2.3kw single oven connected to a 4mm T+E cooker radial (ref method c) Protected by a 32amp MCB
i advised that for the hob to be installed the cooker radial would have to be rewired using 6mm T+E as the 4mm was undersized for the load. but having done the calculations and thought about it I'm not quite sure any thoughts.
7.3kw + 2.3kw = Toal Max Load of 9.6KW = 41.7amps
Diversity applied(no socket at cooker switch) 10A + 30% remainder 10+9.51 = 19.51
with diversity applied Ib <In<It
can't find any reference in the regs to a 4mm cooker radial protected via 32amp MCB as the standard is 6mm/32mcb. Not standard circuit arrangement but as 4mmT+E can carry 37 Amps (ref C) I'm thinking that the additional load may be added.
I would hazard a guess that most don't understand how to do the calculations and just work on a 1.5 = 6/10A. 2.5 radial = 16/20A. 2.5 ring = 32A. Cooker = 6mm & 40A.
4mm radial. Your pulling my leg. No such thing.
Well done IP007 for working it out for yourself.
Well................he has been a member for 3 years... rather more than 3 weeks.
Yes. And I was happy to see that. Fantastic. My other comment was about others not the OP. I think what the OP done was great. I don't understand.
never mind. understanding with age you will get. [ElectriciansForums.net] 4 mm Cooker circuit 32amp MCB
I'd have to say thanks too. :stooge_curly:
I've been told it's calculate the design current, select the protective device rating, then the cable ?
as long as you get the same answer.
Reply to 4 mm Cooker circuit 32amp MCB in the UK Electrical Forum area at ElectriciansForums.net
I would put this down to 433.3.1(ii) - no overload protection needed because the load at the single socket can't overload the cable, being fused...
