4 or 5 pin plugs for 3 phase supply from inverter? | on ElectriciansForums
Discuss 4 or 5 pin plugs for 3 phase supply from inverter? in the UK Electrical Forum area at ElectriciansForums.net
pgrbff
Piemonte, Italy
I have recently bought a 3 phase bandsaw for hobby use and acquired a single phase to 3 phase inverter to power it.
When I looked at buying cable and plugs/sockets for the supply I didn't know if I should choose 3P + earth or 3P N + earth plugs and sockets.
What is the difference and which should I buy?
You need a 3 pin socket because your supply is single phase.
Then you will need to rewire the saw to include the inverter and remove the original 400v contactors.
Also change the motor configuration from star to delta, assuming it is a dual voltage motor (400 star, 220 delta)
That’s 5A per phase. So 1.5 from inverter to motor is ok but inverter needs to have 15 to 20A supply. What spec is the inverter?
  • [ElectriciansForums.net] 4 or 5 pin plugs for 3 phase supply from inverter?
Do you have anyone experienced in 3 phase control and/or any electrician to wire this up to your house?
there are plenty of places where this could go wrong if not thought out and designed correctly.
some might be an inconvenience, others could be a danger.
Unless absolutely necessary get a 5-pin socket and make sure the neutral is connected.
If you have a delta-style load (only using L1-L3, like your motor above) you can ignore the N, whereas if you don't have the N connection for any star-style load in the future (L1-L3 & N) it is going to end very badly for something, or someone!
I have no problems wiring the inverter but I have never used 3 phase.
This is the junction box on the saw and how I believe it should be re-wired. But I am confused about the neutral?
I can buy 4 pin or 5 pin ind plugs/sockets and I just really wanted to know which I should use and why.
A 3 phase motor has no neutral connection
As said before, the socket on your wall needs to be 3 pin as it is single phase.
The inverter to motor cables should be part of the machine wiring and not require a plug and socket.
Reply to 4 or 5 pin plugs for 3 phase supply from inverter? in the UK Electrical Forum area at ElectriciansForums.net
Just stick the 63amp fused connector before the Henley block , or Lucy block as you call it, and your all good, as for your 2nd point, , the...
When I was on the electric board We had a pair of pillocks connect a housing estate to a very large genset, the n lead was in two parts and not...
