4-pin fluorescent to LED help | on ElectriciansForums
Discuss 4-pin fluorescent to LED help in the Lighting Forum area at ElectriciansForums.net
Tjm516
Ohio
Hello, I am having trouble with this 4-pin G24q light fixture conversion to LEDs.
It says to cut the red, blue, black and white wires from the ballast and connect the reds to black and blues to white. I did that, however it doesnt work, my ballast still has 2 yellow wires and I am not sure what to do with them. Here are the pictures of what I'm dealing with.
Sorry to ask a dumb question, I don't really know what I'm doing.
TL;DR
My ballast has 2 more wires than it normally would and I don't know what to do about them in order to bypass it.
  • [ElectriciansForums.net] 4-pin fluorescent to LED help
It is normally quite easy to do conversion. You have to get rid of the ballast, bypass it and wire the mains in directly to the LED. There should be a wiring diagram with the LED. Can you show us that? But in any event forget about the ballast and wire the live/neutral straight to the LED lamp. Remember LED require the correct polarity. It will not work the wrong way around.
DC LEDs require the correct polarity but these are AC.
Ultimately all that is required is to put hot and neutral onto the correct two pins of the lamp sockets.
I'm really at a loss here...
So the main black and white wires, one is bundled with red which leads into the 2 hot (I assume) sockets on the one lamp. The other is bundled with blue which leads to the opposite lamp. There is a single black wire connecting the two lamps and a yellow wire from each that was connected to the ballast.
I bundled the wires together like that based on what the instructions that came with the LEDs told me to do. I don't understand why it doesn't work or how to figure out how to do it. Any ideas?
The instructions you have would work for a ballast and one lamp wired with red and blue, but you have two lamps. I believe it should be wired as the (rough!) sketch below.
Connect all the blue and red lampholder wires together to one incoming power cable (eg white)
and connect all the black and yellow lampholder wires together to the other incoming power cable (eg black).
You might need something better than wire nuts to do this. Ensure you have the power off!
I suspect the LED lamps may have the pairs of pins already connected together, so maybe only one wire from each side of each lampholder is needed, but this would leave you having to insulate the 'spare' wires. Don't just cut them off leaving bare ends ⚡
Since you mention the black going from one lampholder to the other, and nowhere else, you could try connecting the two yellows to the black power source, leaving the black interconnection between the lampholders alone. That would save having to cut it!
You will still need to connect the other side of the lampholders (blues, reds) as before.
That did the trick! Thank you so much. Do you have a PayPal or something where I can send you some $$$?
Hi. Nope, we do this to help people ?, but please give useful postings a ? 'like' or whatever you feel appropriate!
Good to hear the outcome, thanks for letting us know.
Reply to 4-pin fluorescent to LED help in the Lighting Forum area at ElectriciansForums.net
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
