4 way switch with multiple lights | on ElectriciansForums
Discuss 4 way switch with multiple lights in the UK Electrical Forum area at ElectriciansForums.net
jtb198
Wisconsin
I’m installing a new light fixture in a location that just had a cover over the box previously. I discovered that this box connected to another group of lights that is controlled by a set of 3 or 4 way switches. In the box is just one 14-3 piece of romex. I hooked up the black hots together and neutrals together and left the red Traveller alone. The light doesn’t work. I confirmed that power is going to the light. It it supposed to be wired a different way?
There can't be just one traveller, there are always two. So either this is a lighting point with a hot, a neutral and some other unidentified / unused wire, or it is part of the 3-way switch wiring and cannot be used as a light point because it can't have both a hot and a neutral.
As Westward says, the hot at this point might be the red, if there are two switched hots in a run of 14-3 that visits both positions.
Reply to 4 way switch with multiple lights in the UK Electrical Forum area at ElectriciansForums.net
You actually need to use the light switch since that’s where the lights are controlled from. The red wires should be your travelers going to...
I have 2 lights connected to 1 switch. I installed a led light fixture on one light, it had one red wire and one black wires. It was easy to match...
