40 amp breaker for 32amp hob? | on ElectriciansForums
Discuss 40 amp breaker for 32amp hob? in the UK Electrical Forum area at ElectriciansForums.net
Uk
Installing an electric hob that needs a 32 amp supply. Would it possible to use a 40amp breaker with a 32amp fuse switch?
@spark22 it feels as though there is a simpler solution to whatever you have in mind, as it's probably considered a fixed load and diversity may apply. As asked above, what exactly does the manufacturer say in the installation instructions?
A bit more info like cable size, what sort of hob could help get you better advice.
Reply to 40 amp breaker for 32amp hob? in the UK Electrical Forum area at ElectriciansForums.net
This is an interesting issue. I agree with you however I took this to task with a scam inspector some years ago and we agreed to disagree that...
Given the apparent lack of earth, combined with no short circuit or over current protection, I'd contend that luck has been the sole factor...
nicebutdim
N
