40 PC's | on ElectriciansForums
Discuss 40 PC's in the Australia area at ElectriciansForums.net
M
mayfair
Hi guys n gals hope your all well
Busy sorting out a building at the moment its gonna have 40 PC's running with a couple a air cons not a lot else.
Anybody got any words of wisdom ie bond the lot together ? RCD's to c curve ???? what you think?
Its a call centre so thought a making everything live lol
^^ as truckster really.
depending on earth leakage from machines you could only be looking at getting maybe 6 PC's to 1 RCBO (assuming this rather than RCD's) and then your getting close to tripping. Need to start looking at high protective conductor currents.
I would make sure you defo require RCD's, RCBOs
High integrity earthing and loads of radial socket circuits on RCBOs would be my thoughts. If you have access to a earth leakage clamp meter and a fully set up PC you can make a calculated estimate of how many computers you can put on an RCBO.
Reply to 40 PC's in the Australia area at ElectriciansForums.net
